Can you send me another one?
The one you sent worked at first, but the laptop updated the BIOS immediately and at part 2 of the update it became no display, I turned off the laptop and reset the CMOS circuit and then it worked again, but when I restart the laptop it becomes no display again and only draw 0.032 Amp (all the voltages are correct and present), and again the only way to make it work is to turn it off, unplug all power sources, and reset the CMOS circuit. Do you have another BIOS that would not update itself upon launching? I can then lock the BIOS version from the setting.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
